Removing spindles???
Find the unused area between the bearings and hit it with a hammer (not too hard). Once a gap forms at the knuckle stick a screwdriver or something in it and then hit it on the opposite side. Should come right off.
You can always buy a spindle removal tool if all else fails. It threads onto the spindle nut threads and then pushes against the axle stub to remove it.
