I'll be adding this Wilwood master/ hydrobooster to the K5 brakes (ignore wrong gold bracket). Has proportioning valve built into it along with brake warning sensor. Brakes are Dana 60 front discs, Eldo calipers/discs for rear 14 bolt.
SO.... I'll need to remove the stock prop. valve. When I do, I was thinking of just getting 3 adapters for the 3 lines. The Wilwood prop valve has two outlets for the front and one for rear. So two smaller -3AN (3/16) flexible lines to the fronts, and one -4AN (1/4) flexible line to the rear.
Another option is to T the fronts and run one -4AN 1/4" to the T but I'm worried about the smaller T not reaching the threads to each front line.
Would you do it any other different way? Also, not sure how the single stock brake warning wire will hook to the dual terminal.
For 87 K5, I'm assuming 3/8-24 front lines and 7/16-24 rear line
never got that far . typical man i just install stuff and burn the directions .
