removing the wing windows?
solowookie
Wyoming
how possible / expensive would it bit (I'm sure it is 'possible') to remove the wing windows, and have a glass cut to just make the window spawn the entire frame instead of having a wing window?
it seems these stupid things always leak.
$675 just doesn't seem worth it :eek1: there has got to be a much cheaper way to do this... if not it won't happen lol
You could get the glass made, but it would probably be cheaper to buy the kit instead of getting the glass cut, and then paying someone to contour it to stock specs. At least if you buy the kit there is no guesswork.
not to mention you need a custom front track, and window retaining track, upper felt, etc...
My plan is either some kind of plexiglass mounted in place with a seal or just sheetmetal painted black.
Seems to me that the way I sit in the truck I'm not exactly using those areas to open up any blind spots.
