The input shaft on speedo adapter is stripped. The speedometer gauge started jumping around and then quit altogether. I had the transmission and transfer case rebuilt and the problem showed up right then, by luck I didn't blame the shop for this as it was just a coincidence this failed at the same time. I asked the service shop to rebuild the box while they were pulling the transmission again to ship it back to the transmission shop to fix a leak. They said they fixed it with a washer shim. So when I got the Blazer back, I took a look at what they were talking about. Maybe they thought I couldn't afford anything more than a washer, that is the nicest I can be towards them on this point. Their 'washer fix' caught the last 1/8 to 1/16 inch of the good remnants of the key--it failed the first time I got over 60 mph.
After searching, I found there isn't anything online about opening these up and changing that shaft.
These fall under different part numbers depending on over/under ratio
The input key
4.330 KEY, Speedometer Adapter Drive - 73-78 PN 867209
use w/ adapter PNs 326569, 330192, 332537, 368022, 368025, 368026, 465434, 465435
I found new old stock and bought it--I will post what it looks like opening this up [NOTE, TURNS OUT LATER IT IS ONLY FOR AC DELCO BOXES]
The input key
