garlicbreath
So how do you know if you need to replace a harmonoc balancer? I am building my 91 roller motor again and reusing the original balancer. It seems pretty common to just reuse it.
Couple of things to check, the balancer itself could be coming apart, check the rubber part. Also could be coming off the crankChevy305 said:When I was adjusting the timing on my engine recently I noticed that the balancer looked wobbily. Is this normal or do I have a real problem?
pull it off and check the keyway and bolt. Hope not, that can get ugly. (ruined crank ).
