I posted in the garage also, but my steering box on my 1984 military blazer is having issues- i was hearing popping sounds-
Dont seem to have issues with bushings or frame cracks. The box seems to bolted down tight.
But, if someone turns the wheel side to side, the sector shaft and pitman
Arm actually pop down, away from the box. Ive had side to side play in other boxes, but never actually seen the whole shaft pop up and down before...
Should i bother trying the usual adjustments? Or does this up and down movement mean i should go immediately to a new box?
