replaced coil/module... worse off than before*FIXED*
simpleman83
Atlanta, GA
I'd like to start by saying I have searched and everything I've done so far I found elsewhere on this sight.
Ok, so last night my truck wouldn't start. The starter would turn but nothing.... So, checked to see if I had fuel, yes, fuel is being delivered, ok, so then spark, NO Spark. So, every post I saw on here said most likely ignition module... took it into pep boys, they tested, it was good. Replaced that with the electrowhatever goo. So, seemed like from what everyone said on other posts that it would then most likely be pickup coil, so I took the distributer apart, and replaced that... Same effect, when I put it in, starter would turn truck wont' crank over. So, then, maybe its the ignition coil, well, replaced that, and now I've got nothing... The starter won't crank over, and it seems that I've got no electric. checked the fuses, and the ignition one looks good, there is also one called power or something that is big and metal, don't know what that one does but its not a visible fuse..... So, now I have two problems!!! :confused: I'm looking around and people say that maybe the negative cable isn't grounded properly or something, but dont' really know how this could have happened after replacing the ignition coil. I really need to fix this today as it is in a bank parking lot and dont' want to get it towed. Anybody had anything like this before or know what to do?
So, I checked the starter and its good, and there is power getting down to it. The fuses are getting power so it seems that that says that its not the ignition switch. Still getting nothing, no clicking no nothing when you try to turn over. Sometimes the ebrake/check engine lights come on when you crank, sometimes not, the headlights won't turn on. Checked for grounds etc.. things look to be ok.:dunno:
Moved it to another parking lot that doesn't have signs posted about towing but still uncomfortable about just continuing to leave it there. Anyone got anything that could help?:confused:
There are 2 fusible links that I would definitely check. One is located near the starter and the other one is located near the ignition.
