replaced radiator support. now no lights work.
84CUCV
3/4 ton status
NJ for now
its a 90 suburban.. any ideas?? i have tried what i know i have no clue thanks
Battery hooked up?
Turn on the lights, run a wire from the negative post to the ground wire of one of the headlights and see if it lights.
If it does, you still have a bad ground somewhere.
If not, if you have a meter, unplug one of the headlights, test between the hot lead and the negative post of the battery.
No power? Then you probably pinched a wire when you replaced the support and have blown a fusible link or fuse.
i've got them new fancy perpetual headlights..... :woot:
Mike, it's probably the main grd on the pass side...
Ryoken is talking about the little pigtail from the negative battery cable that goes to the core support.
yup, just give em a shake before install and they light forever.... neat....
ok, sorry, i'll stop now.... :whistle: :o
Yeah, lights work better once the battery is hooked up. :haha:
Its always those little nagging details that trip you up.......
