Need advice form those that know what they are doing. I am a novice rally at fabwork or metal work in general. my areas of knowledge are mainly electrical.
My 89 Blazer has its normal share of rust through . my main train of thought at the moment is to replace/repair the floor so that i can install a few parts i have already stored in the garage , to include:
essentially offroad 8 point cage
http://shop.eoronline.com/product.sc?productId=3&categoryId=-1
and a ORd 1 in body lift and energy suspension body mount poly bushings
and a new tailgate , as mine rusted clean through.
the rear threshold is bad from the water seepage around all the seals so i have those parts, the the rear section of the front floor in the corners where the back seat is. Also I had to repair thefloor under the drivers seat. it was torn through , im guessing when the P.O. wrecked it.
I have replacement floor pieces and can replace all of those things. my question is
is the floor still structurally ok for the roll cage to attach to it (after replacing the rusted areas)? or would i gain any structural integrity by lamanating the new pieces over the old.
My thought would be to cut and patch the rust , apply a good primer coat to the top of floor and bottom of the new panels. drill a series of holes in the new panels and weld the new panels down around the perimiter and on the inside mating surface of the holes drilled in the new pieces.
then sealing the whole thing up in a line-x type product.
then installing the lift and cage.
again . dont mean if this is a dumb idea. I am at the know enough to be dangerous stage really , and would love advice form those in the know.
thanks
thanks
