zogthegreat
Newbie
Hi everyone!
I know that this forum is for for GMC Suburbans, but since my engine is the same, I thought I would try asking my questions here.
I have a Vortec 8.1 on my 2004 Damon Challenger motorhome. I was driving it today and suddenly, the engine lost power and the check engine light came on. After turning the engine off and restarting it, I was able to make it back home, although I had the same power loss 3 more times over about 20 mile ride. I hooked up my OBDII scanner, (ELM scanner using Torque as an interface), and I retrieved the following codes:
P0120 - Throttle/pedal sensor switch "A" circuit
P0220 - Throttle/pedal sensor switch "B" circuit
P1516 - Powertrain
P2108 - Powertrain Actuator Control Module
P0107 - Network
Based on the information that I have found Googling, it seems that I need to replace the Throttle Actuator Controller. Here are my questions:
1. I noticed that the Throttle Actuator Controller is rivited on the throttle body. Is it possible to drill out the rivetes and replace only the TAC?
2. Does anyone have the part number for the TAC? I'm going to try to remove it tomorrow, tight fit to get into there!
zog
P1516 - Powertrain
P0107 - Network
zog
