Replacement HD Main Eye Spring Hangers Now Available!
Rugby_7
Glenwood Springs, CO
CLICKY
Perfect for a 4x4 conversion on my dually without having to cut rivets to get a set of factory brackets. If you guys don't already, you should put together a 2 to 4 wheel drive conversion kit now that you have these.
i want a set of these in lift height and a matching set of rear shackle mounts to box & brace and mount lower to keep stuff correct .
i worked on a truck a few years ago and loved it at around 20" of lift on 46" tires . i have a line on a set of 12" springs and could do this easy with a bracket setup like this .
Would love to see the hanger be shifted to the forward position so that the 52 inch springs could be used without all of the extra holes that the DEE EYE WHY brackets have. I’ve just never liked seeing all of those holes.
Treb
