Nice! a quality trans build will take some $$ for sure, hope it brings you many miles of great service!!
Good cooler but I would not suggest that tv cable. There are others available from most trans suppliers that have an end that lends itself well to a variety of applications. The cable you have listed joins in the center by a compression union and it is very easy to kink the cable and ruin it by overtightening. I would also suggest you save your money on the 5 pinion planet sets. They are stronger, yes, but in the 33 years I have been doing this I have not seen a pinion gear fail due to stress. Money would be better spent on improved sprags, clutches, servo, pump, etc.
Greg.....I may have cracked a 5 pinion planetary. And by may have, I mean it's in my souvenir drawer in the garage. I was wailing on it pretty bad though.
And op, sounds like you're going to have a blast with that trans. They really don't like quick forward-reverse shifting though.[/qu
Was that an OE planet or an aftermarket piece? I would like to see a picture of that one![]()
It sounds like the added steps apply only to 1988-1991 models. It's too bad they're in MPH. Even from the factory, there were different gear ratios and tire sizes available, but with guys running everything from 28"-44" tires and 2.73-5.38 gears, 47MPH is too vague for a critical setting like this!
tight as possible at WOT.
That looks like an OE planet but the damage looks like something got between it and the low sprag race, maybe a sprag failure? Hard to tell from the picture but it doesn't look like any gears were broken![]()
TV cable has tension even with the throttle closed, which it did not before; upon pulling the pan previously, the TV valve itself needed help to come all the way out of it's bore. Now it pushes all the way out on it's own.
In "drive", the shifts are firmer than when in "overdrive" which is expected. However, since everything is grabbing as it should, I now feel like I need to regear the axles.
