Replacement rocker panel help
AbramJ
Tempe, Arizona
So I'm probably going to need to replace the rockers on my Suburban and have been searching around for replacements. I found these three options and am confused as to their application. The first one is for the forward most part, that I can see, but what about the other two?
Also does anyone know if these are just the outside skins? I'll also most likely need to replace the lower rear quarter panel in front of and behind the rear wheels. I think I've found those parts too, but again, are they just the outside skins? Thanks for any help.
Depends on how much you need to replace as to which one you need.
The bottom one is for the floor edge if I remember right.
They are the outsides, there is another section that boxes in the back of the rockers
