handloader90
Building!
Hey all,
My 350 is pretty much hanging on by a limb and I've decided to replace it with a 383 Stroker from Blueprint Engines. What I would like to know is what all do I need for this engine to run like it's supposed to and not cause damage to the motor or any other part of the vehicle. I have a 700R4 and 31.5" tires, don't know what the gear ratio is. I use this truck as a daily driver and driving on light trails in the mountains. I'm not looking to turn it into a powerhorse, just want to upgrade engines since I have to replace it anyways. Basically, I want to know the best intake manifold and carb setup, best stall converter, and anything else that you guys can think of that will have my engine running good, strong, problem free and giving it a good proper life.
Also, the install will be performed by Lighthouse Automotive in Colorado Springs, CO.
Thanks in advance for any help!
Here's the motor I'm buying - http://www.blueprintengines.com/index.php/gm-383-bp3832ct1
Also, here's a photo of my truck -
