replacing kingpins efffing sucks!!!
Yea, I can't see the pics cuz of the firewall at work. Will have to look tonight at home.
After I saw those first pics, I thought that I'm gonna have pita struggle when I remove my kingpins.
I had already soaked them with CRC MoS2 for couple of hours. I had 22mm (little loose on kingpin, but that was all I had) L-shaped wrench, 8" long, and heavy hammer (10 pounds or so).
Axle was upside down on a floor, because of CRC soak. First I took piece of flat stock, positioned it under the pin, and gave a good smack with hammer. Then I turned axle 90 degrees so I could hit 22mm wrench straight down. First smack with hammer and damn, pin broke loose!! Second one took three smacks, but it was easy too. I was just amazed. Every where I've read that it's struggle to get pins off, lot of heating and sweat. Either that CRC is really good s**t, or pins weren't ever torqued to specs!
I had the same luck. Coated the king pins in pb blasted 2 days in a row. Then beat my allen wrench with my 10 pound sledge 2-3 times and they were out.
OK, so everyone has tricks for removal, how'd you get the new ones troqued to 600#S. I know you can get some 7/8" hex scrap from a machine shop and use it with a wrench/impact and a big ars bar.
I tried getting mine off when building the axle- used heat and a big ars impact, they didn't move. Now thats its under the truck I think it might be a lil easier.
For torquing them. I use the same concept that I took them off."See above post" Beat the allen key until it would not budge anymore.
