I think most of those floorpan spot welds are rusted away so might be good there, anymore welds that have to be removed?IIRC, I had to cut loose a lot of spot welds from the whole width of the floorpan.
There are a couple of threads going in the body shop dealing with this, go check them outHas anyone replaced the rear floor support crossmember? Can it be bolted in place? Looks like the rear bedside is then welded to it after bolted in? Obviously the tailgate needs to come off first. Basically what is the process to remove and replace?
It came with the Blazer, the box says LMCWere did you get your rear floor support from?
