Replacing Spring
RJB44
Northern Virginia
I recently had my truck (91 Jimmy) into the shop to look at a problem related to it leaningto one side. The diagnosis was that I had a bad left rear spring. The truck had a Rough Country 4 inch lift put on last year prior to me purchusing it. It appears to be off set about an inch to inch and a half on the left. The shop stated that I would need to replace both rear springs so that i had a consisitient height on both sides. They suggested I put Skyjacker's in the rear to repalce the Rough Country. Since the exisiting kit was less then a year old, I called them (Rough Country). The said I would need to give them some purchause information, which I had from the previous owner, and a picture of the truck showing the probelm. They said they would repalce that bad spring, if confirmed. So I guess I need to end up buying one spring at least to go wit the one they repace. I would prefer to use the same make all the way around. need to see if Rough Country sells single springs?
Bob
My k-5 has a similar problem w/ the left rear spring. But mine are beat up for about 7 years of abuse, SUPERLIFT Do'in a shackle flip and going w/ DEAVER SPRINGS . I hear they know what the're doing ,,,,I hope.
