I just replaced mine, it isn't hard at all. That is if you dont care what the old seals end up like. Just take the caps off the ends and pry one end up and work it all the way across to the other side. If it breaks then it breaks, it's the old one and you are replacing it anyway right? Then putting the new ones is the same, but opposite. Just start at one end and snap them in all the way across to the other side. I ended up only having one snap that I couldn't get to lock right in the middle of the outer seal.
