Replacing TH700R4 TV Cable .
I believe the last one I did may have dripped a couple of drops, but no real spillage. This however was on an Astro so the front end was up in the air.
I remeber just a few drops when i unplugged the one out of my '82.
If you use the remote you should be fine. Just make sure to hook the RCA cables back up when you're finished. :)
As long as the vehicle is on flat ground it shouldn't spill any UNLESS the trans is overfull.
