replacing the 14b hub bearings and seals
muddybuddy
1 ton status
Northern, VA
i did look at the 14b bible on pirate, but no info on putting everything back in the hubs. im not sure of the proper way to put them in cuz when i got the axle i knew i needed to replace all of it so i jus beat them out :doah:
any help is greatly appreciated
the bearing in the outer position is droped in. then install race. this is with the race matching the taper of the bearing. taper of bearing is in to the hub. then install clip and seat race to the clip till it contacts clip.
then install race in inner position and install bearing and seal. oil with gear oil before install. and proced .
some have greased bearings. others have just oiled with 80-90 oil.
