One_Ton_k5
Hi all, I am about to buy new gears and ARB lockers for my 14 bff and d60 and I want to get it right the first time.
Here is a little info on my truck:
88 Chevy R30 Crew Cab
93 6.5 Turbo Diesel
93 nv4500
70's era 203
70's era 205
d60 front with leaves
14 bolt full float rear with 4 link
All these parts are in my shop current undergoing full rebuilds.
Now for my question:
I want to get this gearing done right. I used the search function here and elsewhere to try an find as much info as I could and here is what I came up with:
I have the early nv4500 with the 6.34:1 lo range and a .73 OD.
Currently building the setup for an ORD doubler so 1:1, 2:1, 4:1.
My axles currently have 4.56:1's.
I went to 4lo.com and with what I have learned, namely that your final crawl ratio should match the circumference of your tires, and found that 4.88 will be the closest match. Here are the results for crawl and highway uses:
So running 40 inch tires: 40 x 3.14 = 125.64
That also make for 1795 RPM @ 60 MPH.
What do you guys think of these numbers? It is very important to me that the truck handle the on-road as well as the off-road.
Thanks for reading this far.
93 6.5 Turbo Diesel
93 nv4500
70's era 203
70's era 205
