Kenny78
I have checked most of the usual wandering culprits. I am trying to minimize maintainence costs but would spend money if I can find the cause. I traded the draglink and tie rod from a parts truck onto my '85 and realigned tape measure and center box adjust draglink(4'' lift Rough country springs with shims removed and caster angle verified within stock, 35" tires and awaybar removed).
With tire in the air I get no movement and dry steering on the pavement doesnt show any worn components. Watching the draglink to steering shaft relation leads me to believe that its not slop in the box but I havent adjusted the preload on it either. XJ shaft to cure a worn rag joint and a recent rebuild on the steering column for un related issues.
I replaced my other trucks BJ's to get the flat tops off of it(didnt touch any other steering component) and it tracks down the road like a new sports car. Which leads me to my question;
Can I reset my balljoint preload(got the spanner) to 50 ft-lbs? Do I have to unseat the knuckle(meaning complete tear down) or can I just loosen top nut, smack it to jostle it from the sleeve and retorque? I know its probly the long procedure, but I can always hope, right? I just dont want to start only to tie up my sunday (already got plans)
TIA
TIA
