Cheatas
Cheatas are great. We have one at work and it is great. But it stays at the shop for some reason. I work with heavy equipment and use starter fluid Very often. Wrong or right it works and can be done safe enough if you use your head and only use alittle. Start with small amounts and keep working up till you find somthing this works. YOU don't need to use as much as we use on a 60 Plus inch loader tire. On the other hand i think you can get a cheata tank at Harbor Freight for cheap.
