If you can repeatedly trigger this ONLY locking the converter, I'd lean towards a converter/trans problem.
While it is going lean, and it is knocking (and likely pulling timing) if the problem you are experiencing is only during TCC lock, I dont see anything in the logs indicating there is a serious issue with the way the EFI is operating. For it to actually feel like a rumble strip, it would take a LOT of knock, and you are right, it's not there. Your TCC from what I make of it seems to be working properly (unlocking prior to shifting).
TPS base level is self-resetting on TBI IIRC, probably not an issue.
TBI is extremely slow on data speed, so a lot can happen between the data points that might show with much faster data updates.
Fwiw, this guys post isnt bad, and tunerpro seems to show spark advance (in his linked video on Google drive) https://forums.ifsja.org/forum/tire...rom-gm-based-tbi-system-like-howell-for-cheap
On the "normal" log you posted that I evaluated, did it do the same thing every time TCC was locked?
