I have an edelbrock fuel pump and no return on it. the k5 this motor is going in has a return line, how can I hook this up? get a pressure reg with a return on it? thanks
How much is the pump worth? Easiest would be to just get the right mechanical pump. I would think a regulator with a return would be pretty pricey, and add yet another connection in the fuel line.
well I'm running the pump to work with the edelbrock carb. since I have put this pump on I have had no probs with the carb. runs the right psi for edelbrock carb. I guess run stock pump with pressure reg in line but thats kinda the same thing
well the pressure to a edelbrock carb really shouldn't be over 6 psi or so. the factory can run as high as 11psi. when I had the factory on there it would flood and run bad. Maybe I should call edelbrock
