snotrocket71
Registered Member
hey, so i was thinking of reusing a camshaft, its a crane hmv 272-2, i figure it may be decent with the vortec heads on my 400 (the cam was in the motor, i tore it down and some of the lifters were SLIGHTLY mushroomed but the cam lobes looked ok, as did the distributor gear. my concern is the fact that on all of the lobes there is brown streaking that goes up aproximately 3/4 the way up each lobe. is this a serious issue? normal safe wear? or am i just being nutty? where the cam rests on the bearings looks like new. i plan on new lifters regardless of how i go (i already have lunati lifters) if neccessary i can take some pictures if my description aint cutting it. thank you all very much -Josh
