reverse high steer arms?
carpeonnel
Sylvester, Georgia
Been thinking about getting some reverse high steer arms just because the way my front suspension is setup with a zero rate up front, I don't think a normal high steer would clear the leaf springs. But does anybody else run some? Got any pics?
I like the pros of your tierod being back out of the way, but are there any cons? Is there added stress in doing that?
im running NWF reverse hi-steer arms and having the tie-rod in the back is sweet but its also caused some issues that ive had to fix. shock mounts have to be relocated because of tie-rod location (i moved shocks to mounting on the inner C's), spring plate clearance with the tie-rod (custom spring plates from Kert @ DIY4X and use towers on the frame), and you also have to watch out for oil pan clearance as well. its also going to put more stress on the knuckles (same with regular hi-steer) so be prepared to eventually get denbar (sp?) knuckles if your running hydro-assist.
