As most of you know, I've got a 2003 Cadillac Escalade that I have turned into something of an offroad toy. I've swapped out the IFS for a D60 solid front axle and the 10 bolt out with a full float 14 bolt, 3 link suspension front / rear with king coilovers and air bumps. I removed the LQ9 6.0L/4l65e/AWD t-case and installed a replacement 2005 LLY Duramax diesel engine with a ZF6 six speed manual transmission and a 29 spline NP241 manual transfer case. I am very familiar with swapping these engines around, my last build was a 95 Chevy Tahoe with an 02 LB7 Duramax / ZF6 combo. After some effort involving ripping the entire dash out and re-working the entire I/P harness to convert it to manual, relocating the Bose amp to the rear quarter panel above the spare tire tools to allow for a jump seat and installing the pedals I wound up with an install that you could more or less take to GM and have them service it. The dash has no warning lights on at all and everything works right down to the VATS system.
Except for my reverse lights. I am totally stumped.
Using my Tech 2, I can see that both the ECM and the BCM report the manual trans rev switch as ON when I put the trans into reverse, and OFF when I take it out again. I've verified that there is 12V at the BCM and at the ECM input pins with the transmission in reverse. I've also verified that the TBC-B fuse in the I/P fuse block is good (my dome light works fine). I also checked all the other battery, IGN 1, 2 and 3 inputs to the BCM along with all the grounds. When I unlock the truck with my remote and the perimeter lighting is on, the reverse lights turn on. I can also turn the reverse lights on manually with the Tech 2 and they work just fine. The only thing I can see wrong with the Tech 2 is that the Reverse light call PID remains INACTIVE when I put the transmission into reverse.
I was having some issues with the BCM not sending out the power master mode commands properly which was causing a battery drain. I figured perhaps the BCM had a fault internally which was causing it not to turn the reverse lights on. I installed a replacement BCM and programmed it using TIS2WEB tonight. This fixed the battery draw and got the PMM stuff working properly again, but the reverse lights still don't work.
I should mention that the lights worked fine with the auto trans before I started the swap.
Does anyone know if perhaps the BCM is waiting for a status flag from the PCM before it will turn the reverse lights on? Is there any other conditions that need to be met to turn them on outside of the key being in RUN and the transmission in reverse?
