If it were me i would just install a NEW standard rotation water pump and know FOR SURE that it is new and correct. Water pumps are relatively cheap and it's cheap insurance that you have the correct pump on there.
Ok, so I've got the old water pump off, wondering what should be happening with the water pump off completely. If i pour water through the top of the manifold where the tstat goes, should it drain out of the holes where the water pump bolts on? If not then what? I'm thinking that it should, but its not... so that makes me think that there is some kind of blockage within the flow through the block somewhere???? How do I fix that if thats the case? Thanks for the help...
If you try to pour water through the top water outlet it won't go anywhere because you have a thermostat in there that is closed when it's cold.
I just realized what you thought I was saying... I actually meant, if I take the thermostat out and pour fluid directly in where the thermostat is... I already have the water pump back in but still curious as to what should happen?
so hopefully soon and I will be able to really test whether it stays cool with a new radiator/water pump/tstat...
