So apparently I got ahold of a reversed steering box. The long story short I had a 2wd box with crossover, in which I broke several of the bolts, broke off one tab on the box completely, and bent another. So I run down to the local junkyard where I've got all my parts and the guy has a box sitting on the shelf. It looks identical and bolts right up...except after installing it the steering is backwards (i.e. turn wheel right and the wheels go left). Needless to say I was a little upset.
I didn't even know they had a reverse box out there. So what is it out of?
I'm guessing I can replace the input shaft (haven't torn the "new" box apart but I'm guessing that is the difference). Except what is the trick to keeping all of the ball bearings between the corkscrew input and the sector shaft? Anybody have a link to a complete steering box rebuild?
Or should I just put a new 2wd sector shaft into the existing 4wd box (and redrill the hydro-assit ports)?
