Been lurkin on the forum for awhile now and gotta say i ‘ve learned a lot of what I need to start my build. Im glad to finally find a forum like this. Just moved to Washington to go to college, originally from Alaska an plan on taken this truck back with me. The plan for now is to get it lifted and get some good flex out of it, not gunna do a lot of hard wheelin till I can get her back home. the plan is build it for the trails and snow but also has to handle well on the roads.
So I gotta a few questions
1986 chevy ¾ ton with a fresh crate 350 and rebuilt trans
The plan…
Rear:
Diy 4x shackle flip kit (reversed for the 56” and few leafs taken out)
Extended usdr shackles 4”
Zero rates if needed
bumpstops
Front:
DIY4X B52 Kit
52" stock height springs from the rear of a 1/2 ton (few leaves removed)
Extended USDR shackles 4”
Zero Rate if needed
Ord’s Dana 60 Crossover Steering and High Steer Kit (2wd drive steering box)
Ord’s Swaybar Correction/Disconnect Kit™
Bump stops
Ord’s Bolt-in Steering Box Brace Kit and Weld-in Frame Repair kit.
Ord’s 1" Body Lift Kit and Body Mounts (only want to take it apart once)
Ford shock tower mounts
A set of 37x12.50 Super Swamper SSR tires on a set of 8 lug black steelies. Not even sure if they’d fit but I’m set on the ssr’s (wouldn’t mind trimming the fender wells). I also plan on bobin the bed.
So I guess my questions are:
What type shocks to run? Thought about the 5125 Bilsteins not sure what length I need most likely will wait on the shocks itll the springs and lift is in.
Can you still mount a front bumper with the 52’ kit?
Please feel free to add your two cents, any replies will be appreciated.
Let me know if I missed anything.
The plan…
Rear:
bumpstops
Front:
DIY4X B52 Kit
Zero Rate if needed
Bump stops
