Just like the title says I've come up w/ a plan for the k10 (with TONS of help from a few guys on here via AIM) but want you guys to check it out to see if I'm missing something...
REAR:
DIY4X Shackle Flip w/ 6" Shackles
(Mount on "wrong" side)
56" stock height rear springs from a 3/4-1 ton
Zero rate if need be
FRONT:
DIY4X B52 Kit
52" stock height springs from the rear of a 1/2 ton
Extended shackles (Hill 4x4 OR Black Widow Performance)
Zero Rate
I'll run my 14" travel Bilstein 5125 monotubes in the rear and my 5150's in the front (with Ford towers or a shock hoop).
After it's all on I'll measure for the draglink and get x-over installed...
The plan is to run 35's... either BFG AT's OR SSR/TSL/etc.
This'll work well w/ my 4.10's and be easy on my 14ff/10b...
So basically what I'm asking is if I'm missing anything, if it'll sit level, if it'll give me enough clearance to run 35's even w/ how flexy it'll be or other suggestions as far as springs go...
Thanks!
REAR:
FRONT:
DIY4X B52 Kit
Zero Rate
Thanks!
