Picked up a 1 owner 91’ blazer from a guy I know recently, his mom passed and it was part of the estate. Off the road since 09 and basically moved around the driveway until 2018 when they took it to storage where it sat until I got it.
So far I have replaced the tank, sending unit and pump, distributor and coil, plugs and wires and first cleaned the injectors best I could. After this it runs on its own but it still had fueling issues, wants to die out if you give it more than about 1/4 throttle. Just chokes and stalls. I figured the injectors were plugged beyond repair, they were pretty much just dribbling fuel not spraying it.
Replaced injectors today and I can see them spraying now but it’s still doing the same stalling out. Seems to maybe idle worse now.
I should mention I have changed the fuel filter as well.
I have not checked fuel pressure, and I won’t rule out a crappy new pump, but to me it sounds more like a delivery issue farther up the line. I understand how tbi works, I still have my 89 but it has never given me the first lick of trouble so I haven’t had a chance to tear into it.
What y’all think?
What y’all think?
