Kevin Strident
Registered Member
I went from my 87 V-10 to 72 Chevelle, an 05 Corolla, an 00 Cherokee, and once again I'm back in my big truck.
Way back when I began collecting parts for a 14-bolt FF swap. I also have two front 10-bolts, one of which I'll clean up and swap in with the big rear. I had the spring perches moved to fit my half ton springs. I got 4.10 gear sets and master install kits for both axles. I have the 8-lug outers for the front.
What else am I going to need to do?
Can I fit 15" rims over the stock drums or do I need something bigger?
If I do the disc brake swap, I know what calipers and rotors I need but what have you guys don't for an e-brake?
Crossover steering was a fairly new term when I got my truck, as best I can remember. What options do we have for such a setup now?
I'm sure I'll think of more to ask...
