The factory A/C on my 73 K10 was missing the belt to the compressor when I got it, and so I have never used it.
I was doing a evac and R12 recharge on my old Mercedes, and just for giggles I popped the cap on the service port, and pressed the valve... it hissed a bit.
I began to wonder.... so I put my vac pump on the truck... and it pulled a solid vacuum and held it for 2 days(after I pulled the vac, 2 days later I checked it and it was still -35psi)... not sign of leaks!
So, it made me think... am I off my head to want to put on a belt, and recharge it? I still have 10+ cans of R12...
The clutch spins, ok, if it sounds a little gritty thru lack of use. If I grab the pulley, the pump turns, but it too stiff to turn far by hand.
Anyone revived an old system like this, or Should I not bother?
