Rewiring 1973 Blazer
RJG
Registered Member
Cook, MN
I would like to replace every wire and the guages in my Blazer. I'm assuming that many of you have had experience with the same project. If you'd give me some suggestions as to which products you've used and have worked well for you, I'd sure appreciate it. Thanks.
I have used the full kit from Painless wiring. Was pretty complete and made it straight forward. Wires labeled, decent instructions, etc. They have a couple versions depending on how many circuits you want.
There's also a similar thread on here recently. You might do a search.
If you like plug & play, M&H and American Autowire both have pre-made wiring harnessess available. Friend showed me a Painless harness he bought for his Bronco, that looked scary.
I just got a 16-circuit harness from HotrodWires.com this summer. I haven't started install yet, but it looks like a pretty well built kit. All the wires are very well labeled. It was also a ton cheaper than Painless.
Did you get this installed? I need to rewire my 71 K5 and am starting to look at harnesses. Im nervous about diving into this.
