Rewiring/Harness replacement advice experience?
I ditched all the factory gages ,+ put Autometer games in the factory holes. Had to do some grinding with a burring bit.
I'm in the same boat,
might end up going EZ witing with Dakota anolog gauges for the looks of old school.
@CT-BLAZER you have any pics of how your cluster looks after the autometer install.
I've that they don't necessarily point straight but more downwards
Unfortunately, I don't have images or that vehicle.... Flipped it . . .
The gages sat flush , or just recessed in the chrome bezel
As I recall I had to hog out some plastic to to align the gages . The holes tapered + needed to be opened up
Haven't done much on the 91 Blazer.... Have some of the gages....
Will insert gages & film Saturday . . .
Saw the above as a kit for using Component Halogen Bulbs, v. Sealed Beams.
Used similar to run 150 Watt PIAA bulbs, with out burning factory harness.
I just placed my order with Jabin Wood for my wiring harness. VERY expensive but he comes with good recommendations and reviews. I told him what I have and what I need and he says it will all be put together and ready to go. I asked for a sub fuse panel for all interior power (guages, windows, AC, stereo, CB/Shortwave, etc...).
I am going with Autometer Guages (Including GPS Spedo). They will be installed in DIY4X replacement steel dash.
Ill let everyone know what happens with the Jabin Wood harness....
You can get the DIY4X dash in steel?
I’ve got a custom harness from Jabin Wood, it’s super nice and looks factory. I told him what I had, what I did and didn’t want and he tayored it perfectly. Total plug & play.
That said, I found a ton of bad reviews on him after I placed my order which scared me. He did get very slow to reply to my messages, if at all, which was a complaint. When he was about a month late (from his time quote) and not replying at all I messaged him threatening to contest the cc charge, he suddenly started answering and the harness showed up in a week.
The harness was worth the price and way better than the build it yourself “custom harnesses” but the transaction was a little stressful. I highly recommend staying on top of him and holding him to his timeline.
Steel, would probably be OK, just heavy. Shipping would bring the suck, worse than it already does
Good to know
