Most aftermarket springs are a different length from spring eye to center pin, so the swaybar binds. You have to use a disconnect to fix this, even if you don't use it to disconnect. Even with disconnects and lubed bushings the swaybar does seem to make the front a little stiffer on bumps.A swaybar on a lifted truck just rides like crap IMO.
