So I finally went a bought my own trailer and since I went that far I figured I would drop the coin on some fresh straps also. I was at my local trailer/ supply shop and noticed all the straps(nylon ratchet type) were rated for a work load of 3300lbs and a break strength of 10k, same with the axle loops they offered. Is this enough for hauling a full size rig ? Maybe it's because I'm used to load numbers associated with lifting and rigging, because 3300 just seems low for a work load to me
I'm used to having each strap with a work load greater then my lift weight :ex- my small machine weighs just under 4k, I rig it with 3 straps each rated at 6200 straight lift.
Obviously I will not be using only one strap to tie down the rig, but, does that rating sound safe?
I'm used to having each strap with a work load greater then my lift weight :ex- my small machine weighs just under 4k, I rig it with 3 straps each rated at 6200 straight lift. Obviously I will not be using only one strap to tie down the rig, but, does that rating sound safe?
-- is yes, you're absolutely right.
