Rig Part Out- Propane Kit, Hydro Assist, Dana 60, 14 Bolt, Mojave Heater, SBC, ect
stumpjump
Glen Burnie, MD
Complete propane set up currently on a sbc $600
- impco 425 mixer and impco evap
- I have both a vacuum and an electric lock off
- 20' hose with reusable fittings
- 3 aluminum forklift propane tanks (1 full, 2 empty)
- 1 set of tank mounting brackets
Diy4x aluminum dash $750
- auto meter gauges ( tach, volt, vacuum, oil pressure, water)
- northwest auto wire fuse block
- Moroso batter cut off
- water proof head unit and pair or marine speakers
- safety toggle switches
Complete hydro assist and crossover steering set up for a square body Chevy $650
- psc single ended 8" ram
- new hydro boost pump in a psc can
- new power steering box tapped
- Howe tank
- all lines and fittings
- xj steering shaft to go from box to steering column
Dana 60 and a 14 bolt $1900 obo
Dana 60
- passenger side drop 4.10 gears
- balistic fab springless high steer and crossover arms
- solid diff cover
- mad4wd inner axles seals
- lock right
- spicer 35 spline outers
- mile marker 35 splines locking hubs
- new bearings and seals
- 1/4 wall Dom tie rod with 3/4 hiems
14 bolt
-4.10 gears
- solid diff cover
- overson mini spool
- diy4x pinion gaurd
2 bbcs 15" travel shocks $150
Sm465 and NP 205 $250
350 SBC new water pump and alternator, edelbrock intake, Mallory dizzy, new plugs and wires (no carb included) $250
Mohave heater $100
Hydraulic clutch pedal assembly $60
No tilt manual steering column $40
Vacuum booster and 1 ton master cylinder $40
None of these parts were ever wheeled, other than a few laps around the nieghborhood they have virtually no miles.
Text for pics or more info
give me a call if you are interested: 443-286-3063
sell just the gauges off the dash?
Just ordered one from kurt, too bad this wasnt about a week ago...
Also may be interested in your seats/harnesses if you are getting rid of those.
It's not to late to cancel your order with kert :P I don't really want to separate the dash and gauges.
The seats went to a buddy of mine and harnesses are in my new wheeler
gotcha. Well if you change your mind, let me know id be interested.
Would you sell the Lock-rite out of the 60? I'd even send you my spiders to keep it complete...
