You need a special tool to remove steering wheel and another to hold the lock plate down, then a good pick and small flat screw driver to work the snap ring out of the Grove.
I cut the large flat plug off the old switch, after I check that the wires all match new switch. I then tape bailing wire to the old wires. Remove Philips screws pull switch and wiring out, leave bailing wire in the column. Now you need to remove wires from new plug, take a picture first, the plastic plug will have a tab that locks the terminal in. Once that is done tape the wires to bailing wire, as neat and small as you can. Gently pull push wires back through column. Might need to use tilt to make it easier. Replace plug ,screws, lock plate, wheel. Gtg
