right turn / brake light not working. Turn signal switch?
metalneverdies
oklahoma
My right turn / brake light stopped working all the sudden. All lights except the right turn / brake light work with the brake pedal, turn signal switch, and hazard switch.
I followed the wire all the way to the firewall checking for voltage at different points, no luck. Does it sound like the turn signal switch? Don't want to throw parts at it, but other than the switch I am not sure what else it would be.
Pin "D" on the right rear light connector seems to be the correct pin for the turn / brake light. It is dark green on my truck. Yellow is the left rear turn / brake.
Thoughts?
have you placed power to the green wire at the base of the column. Sounds like a bad turn signal switch.
I have not yet. I will have to remove some interior parts to get to that connector. I just traced all the wires from the light to the firewall.
