gmcman
Registered Member
I just got new tires mounted on a set of rims I bought over a year ago. Come to find out the bolt pattern is correct but the center hole is about 1/4 " too big around the hubs. Is this a problem? Can you totally depend on the studs to hold the tire centered or do you really need the center to fit perfectly? I am running them at the moment but thought I would ask for some advice!! Thanks guys!!
