Rims with paddles question
Front tires will be 33's. I am concerned about rolling the tire because they are not bead lock wheels. I need to check paddle size they were on my neighbors ranger but they look about 33 as well
If they are 33's then run the 12's. It will keep them at 33 in. This making it easy on your drive train with both front and rear the same. Also the wider the wheel, the wider the tire will stay giving you the best floation.
