S SHAPER Registered Member Joined Oct 11, 2006 Posts 68 Reaction score 0 Location Western PA Sep 3, 2008 #1 Will a 10 bolt 3.73 rear ring and pinion set work in a front 10 bolt or is the gear set reversed? Thanks guys.
Hogback Fabrication 1 ton status Vendor GMOTM Winner Joined May 26, 2003 Posts 10,818 Reaction score 1,421 Location New Castle, CO Sep 3, 2008 #2 It will work but realize that changing gears isn't a simple remove and replace type deal.
S SHAPER Registered Member Joined Oct 11, 2006 Posts 68 Reaction score 0 Location Western PA Sep 3, 2008 #3 38377k5 said: It will work but realize that changing gears isn't a simple remove and replace type deal. Click to expand... Could you explain that for me? I have an install kit for a rear 10 bolt. can I use that as well?
Hogback Fabrication 1 ton status Vendor GMOTM Winner Joined May 26, 2003 Posts 10,818 Reaction score 1,421 Location New Castle, CO Sep 3, 2008 #4 The gears, carriers, bearings, etc. are all exactly the same; front or rear. As for swapping gears from one housing to another, you will need to setup the gears again. Read here, its fairly involved and requires some special tools. Last edited by a moderator: Sep 3, 2008
S SHAPER Registered Member Joined Oct 11, 2006 Posts 68 Reaction score 0 Location Western PA Sep 3, 2008 #5 NICE. Thanks bro! Thats perfect.
