Ring compressor, raised arm, conversion joint, tube adapters
neverendingproject
Tulsa, OK
I have
1. 4.030 ring compressor (aluminum one piece) SOLD
2. raised steering arm for D44/ 10 bolt 4inch lift powdercated black 40 shipped
(note: all the holes will have to be sanded out because I accidentally forgot to NOT powdercat them.)
3. 1310 to 1350 conversion joint, new never used. 20 shipped
4. Tube adapters 7/8-18 thread left and right, made for 1-1/4 ID tubing. 35 shipped
I was going to use it one my rear driveshaft for my axle swap, but I had an S44 joint and not a 1310. I would think you could use it in the front application too.
swap to what?
if I can use it on my 10-bolt - 14-bolt rear swap in a '91 Burb I'm interested in it
