I searched but could not find an existing thread that applied to what I am doing.
What I have:
1) 1974 Front Differential - DANA 44 10 Bolt 8-1/2" Ring Gear & 26 Spline Pinion geared 3.07
2) 1974 Rear Differential - GM 12 Bolt 8-7/8" Ring Gear & 30 Spline Pinion geared 3.07
What I am doing:
I have completely restored the axles and have purchased new bearings, shims, seals, pinion nuts, etc. The carrier and the ring and pinion are original.
What I need to know:
Should I buy new rings and pinions.
Backstory on why I'm asking the questions. I've been able to get the diffs put back together but the patterns never seem quite right. I made the mistake of not measuring backlash before disassembly and so I don't know exactly what it looked like numbers wise as original. So, I have a relative who has been a mechanic and shop owner for 40+ years and I asked him if he would help me get it all sorted out. After going through everything he strongly recommended replacing the rings and pinions. His view is that the existing (original 50 year old) gears have worn together and since I don't know what the original numbers were, by replacing the bearings, races, etc. it will be almost impossible to have them match up exactly as they were. He thinks there will be noise and "could" result in metal flaking and additional wear that might undo all the new stuff I'm using. Thus, in some undeterminable mileage I could be back inside both diffs replacing everything again plus the rings and pinions.
I should also mention that both ring and pinion look to be in good condition. No overheating, warpage, chipped teeth.
I've looked at the YouTubes and many forums and this has been the first time I've seen this view expressed.
What do you guys (and gals) think?
What I have:
What I am doing:
