ROAD TRIP!!!
Leaving Thanksgiving afternoon and heading south on I-35 to make a detour east to drop off some parts to a member here.
Will be heading straight down to Ft. Smith to camp overnight and then Friday meet up with Justin (jackedjimmy350) to load up the '87 V30 I already bought from him.
We want to scrounge around the north/northeast/east part of Oklahoma for derby cars. If you know of any, please advise. Early 70's Impala's are the hot ticket.
I'm listing all the crap I have to sell down below. Any members around the routes from central Kansas to Ft. Smith can take advantage of delivery of any parts. If you're near and can't make it, I can leave it with anyone who can hold onto the stuff, etc.
Lets begin...
'89 New Yorker: 3.0, six cylinder, runs good but started smoking from sitting a while since I bought a '98 Jimmy. Probably needs valve seals. Good car, good gas mileage, automatic, air, power everything, needs a brakeline fastened to the prop. valve and brakes bled. $500 firm, with clear title. Have another set of good tires in the trunk.
'74 D44/12bolt combo, factory 4.10 gears, recommend both to be rebuilt. $250 for the pair.
30 x 9.50 x 15 Eldorado ZRT tire, mud grip, very deep lugs/tread, $25.
31 x 10.50 x 15 Goodyear Wrangler RT/S tire, deep tread, $25.
31 x 10.50 x 15 Uniroyal Laredo tire, deep tread, with GM Ralley rim, $40.
Flow-thru air gate, not sure of brand, good shape, white in color, $40.
Budweiser empty keg, good for fuel tank? Air tank? Your call, $40.
'57 Chevy p/u hood, excellent condition, 99.9% rust free, very minor, minor dents, $100 firm.
465 tranny, 10 spline, out of an '83 K30, with bell, shifter, knob and boot, $50.
L98 serpentine pulleys, crank and cam pulleys, good condition, $50 for the pair.
6" Skyjacker raised steering arm, $75.
L98 'vette valve covers, off an '87, $50 for the pair.
10 bolt steering knuckles, non-flat top type, good spares or whatever, $50 for the pair.
'74 GM hood, excellent condition, want it gone, $40.
'73 - '80 chrome front and rear bumpers, with brackets and bolts, $100 for the pair.
14FF, out of '73 C20, unknown gears but will check, complete hub to hub, $100.
Mech. clutch/brake pedal assembly, with Z-bar, out of an '83 K30, $25.
Roll bar kickers, no main hoop, just two legs that bolt onto wheelwells, excellent shape, $40 for the pair.
Adjustable hitch, unknown class rating but its heavy and strong, will fit SWB and LWB, $75.
4 core radiator hold-down and BBC fan shroud, $25 for both.
Valance, fastens under front bumper, brand new but had it for a while, $25.
D60 Power Train lockout hubs, full handle/grip type, has one broken part which can be welded, knobs have been glassbeaded to remove all paint, complete, $50 for the pair.
'58 and '59 p/u hood emblems, $25 each.
15 x 14 Weld Racing Super Single II wheel, only have one, 6" backspacing, 8 lug on 6.5" bolt pattern, brand spanking new, never mounted, $100.
10 bolt carrier, out of a '79 front axle, with spiders and pin, $25.
14FF spiders and gears, 4 pin type, fits open diff carriers, weld these up to make your spool, $35.
10 bolt yoke, off '79 front axle, 1310 series yoke, $15, no hardware.
14FF shafts, excellent shape, cleaned up, use for spares, etc., $50 for the pair.
14FF ring & pinion in carrier support housing, yoke has bad holes, gears are in good shape, 3.73 ratio, $75 for everything.
D44/10 bolt full-time drive slugs, out of a '79 K20, cleaned up, $30.
K30 e-brake cables, brand new, never mounted, fits '83 on up K30's, $40 for the pair.
I also have a '74 full hardtop for $50 but waiting on a member who may be interested in a '91 K5 I have and he talks of possibly converting it to full convertible.
Lets begin...
