cerryblazer
Registered Member
http://www.flickr.com/photos/91146104@N07/8278306156/
hi guys! i'm Fabio from North Italy and i have a 1981 blazer k5 with a carburetor problem
are you an expert of rochester quadrajet carb?!
i don't see the jets of gas go out into the venturi!
i replaced all parts with a repair kit but not good news.
i don't understand why, as the pic in the link, when i push down the accelerator pump, the fuel goes out from the holes indicates with "red arrows".
while the good position would be the holes with the yellow arrow, because the squirts of fuel would be exactly above the venturi holes and where i saw them last times!
i found my old carb, the original, i opened it and i saw that there were two or three different parts compared to the second carburetor.
the old one, has a small barrier with a small hole in the position indicates from the "blue arrow" and as you can see in the carburetor in the pic. the new one, not.
then, the old one, has a black plastic cap where there is the "red ring", while the new one not!
i tried the carburetor also with these parts, but it doesn't still run!
how can i see the jets of fuel in the venturi holes!?!?!
please help me!
thanks for attention!
Fabio
please help me!
Fabio
So smooth through the RPM range.
