ciffer
the k10 stalls during warm up at idle unless i keep slight pressure on the throttle. i am not sure what model. once the engine is warm it idles like a champ.
it has an original rochester quadrajet. i think the carb is from the 1972 donor vehicle, not the original 305 but i am not sure.
the engine will also sometimes stumble off idle and almost stall, it will do it at all engine temps but is worst when cold. stumbling is more common after idling at a light, worse if it was a long light.
the weather has been pretty cool lately.
That depends on what you have ie stock 350,383-- cam, ect. to check the vacuum advance you will need a timing light with a dial on it or you can put the light on and apply vacuum to the advance hose and see if it advances.
